03-22-2007 05:09 AM - edited 03-13-2019 04:00 PM
hi,
an outgoing fax call blocked my voice port. it stays in a busy state for days... shut and no shut doesn't put the voice port in a dorm state again, only a reload will correct it... is there any solution instead reloading the c2800?
many thanks
Solved! Go to Solution.
05-06-2007 09:58 PM
Dino -
If you are running IOS 12.4, This seems to be attributed, possibly, to a known bug with the FXS port:
Cisco bug ID CSCse83674
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCse83674
03-23-2007 05:37 AM
Seems odd - if you physically disconnect the cable does the port clear?
If so, use a new cable with only the necessary 2 pins cabled up.
Aaron
Please rate helpful posts...
03-23-2007 11:08 AM
we do not have access to the equipment. we must solve remotely. but it is properly cabled...
i will check the ios version..
thanks
05-06-2007 09:58 PM
Dino -
