FAX doesn't work any more when using PA-VXA-1TE1-30+ instead of NM-HDV-1E1-
we used one 2610 with NM-HDV-1E1-30 connecting to our PBX before we purchased the in centre location. We have several remote offices where we have NM-2V with VIC-2FXS connected to little PBX. Voice and fax worked very well.
Now we got the PA-VXA-1TE1-30+, we inserted it into 7206VXR, the configuration is nearly the same as NM-HDV-1E1-30. The probelm appeared, voice work well, but fax doesn't work any more. the fax rate negotiated between two fax machines is only 2400, couldn't oprated at all. The command "fax rate 9600" in our configuration files seem don't work like before.
we check the parameters between central and remote, nearly the same. the IOS version of 7206 is 12.2. Can someone give some advice?
1 REPLY
Bronze
Re: FAX doesn't work any more when using PA-VXA-1TE1-30+ instead
If you haven't already start off by checking for bugs.
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
107
