Fax doesn't work on ATA186
It has been on this forum before (not by me!), but there was no solution then.
I have an ATA186, configured as H323-device. I can Fax with the machine on line1, but I can't recieve a fax! How can I get this to work?
I have put 'fax protocol t30' on 'voice service voip', but that doesn't help.
Any help is appreciated.
Thanx,
Sascha
rmg
Re: Fax doesn't work on ATA186
Maybe I'm wrong, but I thought the ATA186 could only do fax passthrough, whereas t.30 is fax relay?
ok, but our 3640 with the E1 doesn't support fax passthrough! (IOS 12.1(5)T8)
Bronze
I have tested the ATA s with the following Software " v.211.ata186 (Build 0803a)" and it works well.
You must disable the " voice service voip".
Use the command "fax rate disable " on the voip dial-peer.
Configure the fields in the ATA with the following Commands:
ConnectMode: "0000e001" if you have configured the "a-law codec on the voip dial-peer or
"0000a001" if the codec is u-law on the voip dial peer.
AudioMode: 00140014
Good Luck
Mehmet
146
