Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Fax + FXS + DID = outgoing fax problem?
Hi there,
CUCM 6.1
IOS gateway with H.323
4 port FXS
PRI with DIDs
I am reading in some articles that fax machines on FXS ports on PRI DIDs, can only receive faxes and can not send faxes. Has anyone experienced this? Has anyone been able to set this with a working incoming and outgoing faxes?
thanks,
Rdianat
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Fax + FXS + DID = outgoing fax problem?
They mean FXS ports in analog DID signaling mode, that is a special telco arrangement. And that is correct, no outbound calls on these lines.
Nothing to do with regular FXS ports when the telco connection is PRI.
Please remember to rate useful posts with the scrollbox below.
Do you have network-clock-participate and -select for the PRI on the GW ?
Please note: I don't have anything set yet. I will be doing it in near future and I have heard conflicting information from some people that fax can not be sent outbound when connected to FXS and when used with PRI DIDs.
My question is: Have you ever set it working this way?
I am not trying to make it work as I do not have it ready yet. I am simply asking if anyone has set it working? This is important as this is a tight deadline implementation and I do not want to get into surprise situation.
So please do not ask what is my configuration.
rdianat
It is absolutely possible to have incoming and outgoing fax work with DID.
Thanks for your strong YES bvilacqua.
My confusion is coming from:
Cisco Voice Gateways and Gatekeepers
By Denise Donohue, David Mallory, Ken Salhoff
Publisher: Cisco Press
Pub Date: August 17, 2006
Print ISBN-10: 1-58705-258-X
Print ISBN-13: 978-1-58705-258-3
Pages: 648
Note
You cannot use FXS ports that are configured for DID service to place outbound calls.
rdianat
292
