Fax Issues with ATA and 3640PRI
Need help with Faxing with the ATA188, and the 3640 with NM-HDV-2t1. Have 12.3(11)T code on router and running 4.1.3 CCM.
Hearing funning tones when dailing and saw an article to change audiocodes for ATA. pasted in is my mgcp config.
Help anyone?
mgcp
mgcp call-agent 10.0.7.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip redundancy
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0.108
mgcp bind media source-interface FastEthernet0/0.108
mgcp profile default
Re: Fax Issues with ATA and 3640PRI
Check for clock slips and other errors on the PRI controller.
Brandon
How do I do that troubleshooting?
Are you saying that this config looks sound and that the ATA shouldn't need a configuration change from default?
The config looks good. There should be no change needed on the ATA. Take a look at the following document regarding T1 error events and troubleshooting.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801095a3.shtml
Hope this helps.
Brandon
109
