You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Fax machine dialing from FXS without 9 in CCME
Hi everyone,
I have a fax machine connected to a FXS port (voice-port 0/1/0). We use the PRI for inbound and outbound calls (voice-port 0/0/0:23). I can currently make calls from the fax through the PRI but I have to dial 9. How can I not force the fax machine to dial 9?
Thanks!
Stephen
  • Other Collaboration Voice and Video Subjects
Re: Fax machine dialing from FXS without 9 in CCME
Is this a H323 or MGCP gateway ? If using H323
Use separate dial-peers for dialing from fax machines
dial-peer voice 1 pots
destination-pattern [2-9]...... (7 digit dialing in this case)
port 1/0/0:23
Then use COR so that phones wont have access to these dial-peers. Only fax machine ports should.
Thanks! Definatly steered me in the final direction. All works now!
Stephen
Go to the gateway configuration page on CM. Click on the appropriate gateway and view the fxs port you want to prepend the 9 on.
If you scroll down towards the bottom of the page there is a spot to put a prepend digit. Put a 9 in this field and reset the port. You should be good to go after that.
334
