Fax machine doesnot allow international
Dear sir ,
I am using CCME , i have configure internalional and national dialing and i can easily dial international calls by my ip phones .i have configure a login option when user login in phone he or she able to dial inernational calls but without login he/she can only dial national/local calls. i am facing a probem with my FAx machine which is connected to ATA device . with Fax machine i can send fax nationally/locally but cannot send fax internationally. and i didnt found any option in fax for login as we have in ip phones. please let me help what i am doing wrong.
some of the configuration are below i have try with removing pin command in ephone 68 but same problem.
url directories http://10.198.160.7:80/localdirectory
url services http://10.198.160.9/voiceview/common/login.do
url authentication http://10.198.160.9/voiceview/authentication/authenticate.do
login timeout 120 clear 19:00
after-hours block pattern 1 900
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
ephone-dn 3 dual-line
number 2602
label business analyzer
name Ghada Konsowa
call-forward busy 4000
call-forward noan 4000 timeout 10
corlist incoming AllowedInternational
ephone-dn 68 dual-line
number 2667
label Fax1
call-forward noan 4000 timeout 40
ephone 3
no phone-ui speeddial-fastdial
no multicast-moh
mac-address 001F.9E26.CC61
username "KONSOWAG" password 12345
type 7975
button 1:3
ephone 68
no multicast-moh
mac-address 001F.9EAC.A6F3
max-calls-per-button 2
username "Fax " password 12345
type ata
button 1:68
pin 12345
i can easily international call by ip phones after login.
1 REPLY
Re: Fax machine doesnot allow international
Hi zeeshan2007,
To exempt ephone 68 from call-blocking; you need to add after-hour exempt on ephone68, check this link for further explanations:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1014483
HTH,
136
