Fax not completly
I have a ICS7750 with a 16 Port Analog and 4 Port ISDN BRI Gateway. The Problem is with the Faxes they are not completly some Text is or only the half site is missing.
Thanks for all helps
Re: Fax not completly
The faxes are coming through incomplete? Is this in-bound faxes, out-bound faxes or both?
This is in- and out-bound.
Regards Markus
Blue
Please post your config.
sh run
Building configuration...
Current configuration : 4078 bytes
version 12.2
hostname AnalogGW
enable password
voice-card 0
ip subnet-zero
voice call carrier capacity active
voice echo-canceller extended
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.101.60
ccm-manager config
interface FastEthernet0/0
ip address 192.168.101.64 255.255.255.0
speed 100
full-duplex
ip classless
no ip http server
logging 192.168.101.60
snmp-server community public RO
snmp-server community voice RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rsvp
snmp-server enable traps pppoe
snmp-server enable traps bgp
snmp-server enable traps ipmobile
snmp-server enable traps dial
snmp-server enable traps voice poor-qov
snmp-server enable traps dnis
snmp-server enable traps xgcp
snmp-server host 192.168.101.60 public
call rsvp-sync
voice-port 0/0
echo-cancel coverage 24
cptone CH
voice-port 0/1
cptone CH
voice-port 0/2
cptone CH
voice-port 0/3
cptone CH
voice-port 0/4
cptone CH
voice-port 0/5
cptone CH
voice-port 0/6
cptone CH
voice-port 0/7
cptone CH
voice-port 0/8
cptone CH
voice-port 0/9
cptone CH
voice-port 0/10
cptone CH
voice-port 0/11
cptone CH
voice-port 0/12
cptone CH
voice-port 0/13
cptone CH
voice-port 0/14
cptone CH
voice-port 0/15
cptone CH
mgcp
mgcp call-agent 192.168.101.60 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
application mgcpapp
port 0/0
dial-peer voice 2 pots
application mgcpapp
port 0/1
dial-peer voice 3 pots
application mgcpapp
port 0/2
dial-peer voice 4 pots
application mgcpapp
port 0/3
dial-peer voice 5 pots
application mgcpapp
fax rate disable
port 0/4
dial-peer voice 6 pots
application mgcpapp
port 0/5
dial-peer voice 7 pots
application mgcpapp
port 0/6
dial-peer voice 8 pots
application mgcpapp
port 0/7
dial-peer voice 9 pots
application mgcpapp
port 0/8
dial-peer voice 10 pots
application mgcpapp
port 0/9
dial-peer voice 11 pots
application mgcpapp
fax rate disable
port 0/10
dial-peer voice 12 pots
application mgcpapp
fax rate disable
port 0/11
dial-peer voice 13 pots
application mgcpapp
port 0/12
dial-peer voice 14 pots
application mgcpapp
port 0/13
dial-peer voice 15 pots
application mgcpapp
port 0/14
dial-peer voice 16 pots
application mgcpapp
port 0/15
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
line vty 5 15
password
login
end
Current configuration : 3440 bytes
version 12.2
hostname IsdnGW
logging buffered 4096 informational
enable password
voice-card 0
voice-card 1
ip subnet-zero
no ip domain lookup
ip cef
isdn switch-type basic-net3
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g723ar63
codec preference 5 g723ar53
ip address 192.168.101.63 255.255.255.0
speed 100
full-duplex
h323-gateway voip interface
interface BRI0/0
no ip address
isdn twait-disable
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/1
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI1/0
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI1/1
no ip address
isdn twait-disable
isdn static-tei 0
ip classless
no ip http server
call rsvp-sync
voice-port 0/0
echo-cancel erl worst-case 3
compand-type a-law
no comfort-noise
cptone CH
voice-port 0/1
compand-type a-law
no comfort-noise
cptone CH
voice-port 1/0
compand-type a-law
no comfort-noise
cptone CH
voice-port 1/1
compand-type a-law
no comfort-noise
cptone CH
destination-pattern 0T
direct-inward-dial
port 0/0
preference 1
direct-inward-dial
port 0/1
preference 2
direct-inward-dial
port 1/0
preference 3
direct-inward-dial
port 1/1
dial-peer voice 700 voip
destination-pattern 7..
voice-class codec 1
session target ipv4:192.168.101.60
fax rate disable
fax protocol pass-through g711alaw
no vad
gateway
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
line vty 5 15
password
login
no scheduler allocate
end
Sounds like a codec issue. Do you have the fax/modems set to use 711? Some times I have seen customers set there ata or fxs ports in a location that uses g729. This would case the fax to be compressed, that could case it to fail just about every time.
136
