08-25-2014 12:11 AM - edited 03-15-2019 05:29 AM
If a user send fax from analog line (not all) , my fax server does not receive fax from the voice router
Below is the configuration
dial-peer voice 306 voip
destination-pattern 'number'
session protocol sipv2
session target ipv4:10.0.1.1:5062
dtmf-relay rtp-nte
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
What does it mean by
dtmf-relay rtp-nte
codec g711ulaw
Do i need to change something on voice router
Sib
09-02-2014 06:12 AM
It is hard to tell without the whole picture and debugs but here is a base dial-peer I always use for FAX, then I just tune it based on specifics on the environment:
dial-peer voice 3223642 voip description fax from pstn to FAX server preference 1 destination-pattern <patter for FAX server> translate-outgoing called 82000 session protocol sipv2 session target ipv4:<ip of FAX server> session transport udp codec g711ulaw fax rate 14400 fax protocol t38 ls-redundancy 2 hs-redundancy 0 fallback cisco
Must of the FAX servers I deal with are openText / Right FAX and provably CUCM in the middle, in such case just put the IP of the CUCM server instead of the FAX server.
Christian Nuche
TAC Eng.
09-02-2014 08:34 PM
Thanks Mr Nuche
Can you post the description of each commands or any helpful link.
"Must of the FAX servers I deal with are openText / Right FAX and provably CUCM in the middle, in such case just put the IP of the CUCM server instead of the FAX server."
If cucm is in the middle , how you are connected to the fax server ?. Is it sip trunk
Thanks again
