Fax not working for particular number
i am using vg248 to connect fax ( which is G3 fax mac )
i am not able to fax to a particular number from the ip system.
not problem with route plan.
i can fax from outside ip .
i tried to change the fax parameter for the port . - changed from fax reley to t.38 - still not able to fax .
can anyone suggest way where sould i look for solution.
1 REPLY
Silver
Re: Fax not working for particular number
check the following fax relay enable, fax error correction mode override and NSE type "IOS Gateway" are cheched, in gateway configuration.
This URL should help you:
http://www.cisco.com/warp/customer/788/AVVID/fax_6624_h323gw.html
142
