Are you trying fax-relay or not?
If no fax-relay, be sure to set the codec that fax is using to g711ulaw, any higher compression will likely distort fax tones.
If yes, fax-relay, then make sure that the call is indeed using fax-relay on both sides, and negotiating it correctly by doing "show voice dsp" and show voice call summ.
Then look at the statistics of the call .
term mon
show voice call sum (pick up the channel, say 1/1/1 and do)
show voice call 1/1/1
this will show any errors on the DSPs , any jitter indications, or any other problems, basically be sure that the counters are very small values and are not incrementing.
Hope this helps.
