fax problem - AS5350 with 827-4V endpoints
Hi all , We can send faxes from the 827-4V endpoints out to remote PSTN connected fax , but we cannot receive at the 827-4V´s -- handshaking occurs between faxes but the call always drops and no fax data gets through. I have run "debug vtsp session" and this always shows "disconnect cause normal". I have also "fax-relay ecm disable" and "fax rate disable" on the VoIP dial peers. I am kind of baffled as to why it works one way , but not the other -- voice calls are fine . All help appreciated on this one -- Any ideas guys ?
Thanks.
1 REPLY
Re: fax problem - AS5350 with 827-4V endpoints
I should have pasted this in :
5350#show ver
IOS (tm) 5350 Software (C5350-IS-M), Version 12.2(2)XB3, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 10-Feb-02 00:31 by hwcheng
Image text-base: 0x600089C8, data-base: 0x61180000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Experimental Version 12.1(20000922:142008
) [nag-flo_t_0110 101]
101
