Fax T.37 Store and Forward-On Ramp Gateway
Hello: I have a problem, when using the wildcard "$d$" in a MMOIP-Dial-peer on an on-ramp-gateway. (Cisco2821 IOS 124-4.T1). When configuring the "session-target" (Mail-receptor)in the MMOIP-dial-peer, you can insert a normal e-mail address like (session target mailto:x.y@company.com). So it works fine, the Message Transfer Agent of the router delivers a correct mail-address to the mail-server (MS-Exchange), like "<x.y@company.com>".
But when I use the wildcard "$d$" (called number, DID) in the session-target (session target mailto:$d$@company.com), to simplify the configuration of the gateway (so I don´t have to configure a seperate MMOIP-dial peer for every mail-user)the router-MTA delivers the mail-address to the exchange-server in a format, which is not accepted "<mailto:53647@company.com>". The difference is the "mailto:", that is added to the email-address (only added, when using the wildcard), so the mail-server responds "Invalid mail-address".
Doe´s anybody know, how to avoid this "mailto:"-addition, when using the wildcard "$d$"? Many thank´s in advance-Peter
PS: Here´s the "debug fax mta detail":
1.So it work´s fine:
Feb 8 16:24:23.228: //-1/C860340F8040/SMTPC/esmtp_client_engine_writeln:
(C)S: MAIL FROM:<FAX=0073278022974@company.com> RET=HDRS
Feb 8 16:24:23.232: //-1/C860340F8040/SMTPC/esmtp_client_engine_write:
return code=0
Feb 8 16:24:23.764: //-1/C860340F8040/SMTPC/esmtp_client_engine_getln:
(C)R: 250 2.1.0 FAX=0073278022974@company.com....Sender OK
Feb 8 16:24:23.764: //-1/C860340F8040/SMTPC/esmtp_client_engine_writeln:
(C)S: RCPT TO:<a.b@company.com> NOTIFY=SUCCESS,FAILURE ORCPT=rfc822;a.b@company.com
Feb 8 16:24:23.768: //-1/C860340F8040/SMTPC/esmtp_client_engine_write:
return code=0
Feb 8 16:24:24.312: //-1/C860340F8040/SMTPC/esmtp_client_engine_getln:
(C)R: 250 2.1.5 a.b@company.com
Feb 8 16:24:24.312: //-1/C860340F8040/SMTPC/esmtp_client_engine_write:
return code=0
Feb 8 16:24:24.860: //-1/C860340F8040/SMTPC/esmtp_client_engine_getln:
(C)R: 354 Start mail input; end with <CRLF>.<CRLF>
So it doesn´t work:
Feb 9 09:21:59.181: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_writeln:
Feb 9 09:21:59.181: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_write:
return code=0
Feb 9 09:21:59.713: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_getln:
Feb 9 09:21:59.713: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_writeln:
(C)S: RCPT TO:<mailto:53647.536@company.com> NOTIFY=SUCCESS,FAILURE ORCPT=rfc822;mailto:53647.536@company.com
Feb 9 09:21:59.717: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_write:
return code=0
Feb 9 09:22:00.261: //-1/F08D61FC8041/SMTPC/esmtp_client_engine_getln:
(C)R: 501 5.5.4 Invalid Address
1 REPLY
Re: Fax T.37 Store and Forward-On Ramp Gateway
Nobody any idea, about my issue?
173
