Fax transmission problem
We have a PC with a modem that is connected to a VG248 port. This PC has the Symantec Winfax application to send faxes. Anyone has experience with this app, modem and VG? It is not possible to send fax through the WAN (G729 codec) and it is not able either to send fax to another fax in different company but also connected to a VG248.
Any idea?
The VG port configuration:
Fax Relay: Disable
Passthrough: automatic
The gateway configuration:
mgcp modem passthrough voip codec g711alaw
mgcp fax t38 inhibit
Super Bronze
Re: Fax transmission problem
Are you saying that you CAN fax other outside phones, but NOT one in another company (via the PSTN) that uses CallManager?
Also if it's a PC check the speed it is faxing at and cut it down to 14400 if possible...
I'd check these things first:
VG248
Set on the ports:
Fax Relay:Disable
Passthrough:passthru only ECAN disable
Advanced settings:
Signalling type - IOS
On your MGCP gateway:
no ccm-manager fax protocol cisco
mgcp modem passthrough voip mode NSE
mgcp modem passthrough voip codec g711a (or 711u if that's what you use)
Aaron
please rate helpful posts
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thank you for the suggestions. I will change the passthrough setting to only ECAN disable.
Signalling type is already IOS.
On the MGCP the only parameter I din´t have is
but I can´t add it as the rest of faxes use Cisco fax relay
162
