Fax transmission
My question is regarding fax transmission over H323 IOS g/w. Half-way through the transmission, I get "communication error" on the fax machine, and it can't complete its job. Anyone have any idea how to solve this problem?
I have this config under my dial-peer voip
fax-relay ecm disable
fax rate 4800
fax protocol t38 ls-redundancy 5 hs-redundancy 2
thanks.
--rizal
1 REPLY
Re: Fax transmission
This is a great document to troubleshoot the FAX over IP issues. Give it a try
http://www.cisco.com/warp/public/788/voip/faxrelay_tsguide.html
140
