Fax with CCME 3.4, 2811 and VWIC-2FXS
We have a new CCME setup (PBX style) for a branch office and I have everything setup except our fax machine. I've been pouring over documents that discuss H.323, skinny and all these horribly complex configurations. We're not doing this over a wan as it's going from the router that has the PRI and straight into a fax machine. It should be easy... Call comes in the PRI with the last four digits of 4475:
Called Party Number i = 0xA1, '4475'
I want to take that call or any call destined for 4475 and direct/map it to voice-port 0/1/0.
This has to be simple but I can't find the answer. I am used to full blown CCM and MGCP :(
If someone has a config snippet that I could see regarding this, I would be most grateful. I have about 18 hours left to set this sucker up :)
Thanks!!!!!
Stephen
1 ACCEPTED SOLUTION
Blue
Re: Fax with CCME 3.4, 2811 and VWIC-2FXS
Try this:
dial-peer voice 10 pots
destination-pattern 4475
port 0/1/0
Please rate helpful posts
Blue
Try this:
port 0/1/0
Thank you so much. That helped me fix another problem preventing that from working. I had a connection plar statement on my voice-port 0/0/0:23 that was forcing everything to voicemail that I had put in place during initial testing. I removed that and did some translations.
Thanks again!
Stephen
144
