Fax with IP Telephony Setup
What are the options available to send/ recieve fax to a PC in IP Telephony setup other than Unity/FAX servers ?
  • Other Collaboration Voice and Video Subjects
Re: Fax with IP Telephony Setup
There are several options avilable to you, which include:
ATA-186/188
VG 200/248 (EOL)
Voice Router with FXS cards
AGM Card for cat 4000, 4500, 6000 or 6500
All of the above provide for analog telephone support (i.e. faxes or handsets).
However none of these will provide the fax directly to a PC. As you have mentioned you would need to use some sort of Fax Product to do this, e.g. Zetafax, Unity, Winfax Pro, etc.
David
Bronze
Depends on the setup you have. You can do a T.37 store and forward on a router, and point it to a SMTP gateway to dump all of the faxes in a designated mailbox. No additional software needed, but unless you want to sit and monitor that mailbox you will want to have some small software to help. If you have a Unity server you can use the Third Party Fax tool from answermonkey.net (it is free) and that will monitor the inbox for you and send the faxes out automatically.
Geoff
You can also use T.38 on a router and a product like xMedius.
There is some documentation for a deployment with xmediusfax and unity 3.1?
The information provided on unity admin guide isn't like a regular procedure...
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_administration_guide_chapter09186a00800ea810.html
we haven't local support for this product in Chile.
TIA
Andres Pasten
Cisco Systems Chile
146
