Faxing Best Practice (H323 Gateway with SCCP ATA CCM4.1(3)
I'm writing an advice guide on faxing with the SCCP ATA and H323/Router/PRI , is this the best setup for faxing?
1. Verify voice PRI controller has no slips/errors,etc. It has to be clean.
2. Config t
Voice service voip
modem passthrough nse codec g711ulaw
dial-peer voice XXXXXXX voip
Reference
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a008053b51f.html
3.If you add the above modem passthrough then change the ATA (http://X.Y.Z.A/dev)
Audio Parameters
AudioMode 0x00150015 (default is 0x00350035)
ConnectMode 0x90000400 (default is 0x90000400)
4. Verify you have the second generation ATA-186I1-A, the first generation had DSP problems.
Should I give any other advice?
IOS 12.4(5)a
Callmanager 4.1(3)
ATA 3.02.01(050429A)
ATA ATA030201SCCP050429A.zup
What other tips should I provide?
Bronze
Re: Faxing Best Practice (H323 Gateway with SCCP ATA CCM4.1(3)
Under voip dial-peer put also "fax rate disable" and "no vad".
Also you don't need to put the modem passthrough command in two places. one of them will do the trick.
Are there any tests that show RFC2198 (redundancy) improves fax reliability if implemented in the dial-peer and ata?
160
