FAXING ON A 3640 HELP
I have a 3640 with 12.2XB6. I have a t1 line coming into the router. I want to configure Store and Forward Faxing can this be done? What I would liket to accomplish is the following: A FAX comes in on the t1. It goes to a MMOIP dial peer which then sends the FAX to a mail address. I have configured the dial peers then send a fax to a number, which is $d$ for the user. In exchange the user has an alias of xxxx, which is the number. No matter what I do the MMOIP dial peer never gets initiated. I confirm this by issuing the command debug voice ccapi inout. I know the dial peers are set up correctly. Is there something I am forgetting? If anyone can help I would appreciate it. Thanks in advance.
1 REPLY
Re: FAXING ON A 3640 HELP
according to feature navigator:
http://www.cisco.com/cgi-bin/Support/FeatureNav/FN.pl
Store and forward is not supported in the XB release train of IOS.
It is supported in:
12.2(11)T
12.2(8)T5
12.2(8)T4
12.2(8)T3
12.2(8)T2
12.2(8)T1
12.2(8)T
Feature infor here (it says 3700, but same configs for 3600)
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/plfxrl17.htm
82
