Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
FGD-EANA + info-digits not passing over VOIP
Hi there,
I have this problem maybe someone have done this before that can help me with. I have a T1 using FGD-EANA to get the Info-digits+ANI+DNIS for billing purpose, this way we know when its a payphone call base on the info-digits provided. When the call come in from TDM, and I did the debug vtsp all, I can see the info-digits been sent to our AS5300 but when we forwarded the calls over to the Termination AS5300, the other side doesn't see the info-digits. They only see ANI+DNIS. Here's the Diagram to help out a bit.
TDM-->(Org)AS5300--Internet-->AS5300(Term)-->TDM-->Switch(to play a voice prompt).
Im not sure what's the reason why I can't forwarded the info-digits. There's a setting for pot to forward the info-digits string. But this you have to make up a info-digits to be pass. I wanted to get it based on what the TDM gave to me. Here's my dial peer for the Origination and Termination.
Origination Pots:
dial-peer voice 80099 pots
incoming called-number .T
direct-inward-dial
port 7/0:28:0
Origination Voip:
dial-peer voice 800 voip
max-conn 24
destination-pattern 800.......
session target ipv4:192.168.1.100
Termination Pots:
dial-peer voice 1832 pots
no digit-strip
port 1/0:0
forward-digits all
Thank you,
Trung
1 REPLY
Anonymous
N/A
Re: FGD-EANA + info-digits not passing over VOIP
Normally this issue happens if the command forward-digits all is not given in the terminating gateway. In your case, since this command is given already, I think you might be running into the bugCSCdv00056.
215
