FGD not working
I have an AS5350 and I have been trying to have one of its T1 working using FGD without luck. The AS 5350 is connected to a PABX that accepts FGD as I have an Adtran 500 converting PRI to FGD connected to the same PABX working fine. This was the solution I found for having the Cisco sending the ANI/DNIS information. The calls are in both cases originated from some SIP clients and are sent to the PABX for further process. I was looking at the "call history voice " and find that the Cisco sees the call as "normal clearing(16) with a disconnection cause of 3. But the truth is that at the PABX I am not receiving any digits and the call drops. The PABX sees it as receiving a disconnect signal from the Cisco.
The setup of the controller T1 is as follows:
controller T1 3/1
framing sf
linecode ami
cablelength short 133
ds0-group 0 timeslots 1-5 type e&m-fgd
I tested all variables exept using MF.
As the connection through the Adtran works OK I think that I am missing something in the AS5350 configuration.
Any help will be greatly appreciated.
Juan
Bronze
Re: FGD not working
The "ds0-group 0 timeslots 1-5 type e&m-fgd" command is used to receive ANI on a FGD trunk. In other words, this should be used to receive calls from the PBX only. This same trunk cannot send ANI. In order to send ANI with FGD you have to also add this command to the T1 controller: "ds0-group 1 timeslots 6-10 type fgd-eana"
Here's the full controller config:
controller T1 0/2/0
framing esf
linecode b8zs
Of course you can use whatever channels you need as required. Then create your dial-peers to receive calls on ds0-group 0 and send calls on ds0-group 1. I've used this config with 2811 and 2801 routers, but not with an AS53xx, so I am making a few assumptions here. This is also assuming you want to send calls in each direction. Hope this helps.
Re: FGD not working
Thank for your answer.
This T1 is intended to only carry calls from the Internet side to the PABX so if I got right your advice I should set up all ds0s as fgd-eana. The other difference I found is that you used framing esf and linecode b8zs. I should use ami/D4. In my actual configuration I just used 5 ds0s for testing purposes. I will try it and let you know the outcome.
Juan
Re: FGD not working
I tried your suggestion. Now I don't get hanged up but I am not receiving ANI nor DNIS. I see the siezure the PABX winks waits for the ANI, receives nothing, winks again, receives nothing and finally sends the message saying that didn't receeived the required info and hangs up.
I tried also to use ds0-group 1 timeslots 1-5 type fgd-eana ani-dnis with the same result.
At the call history voice screen I am getting:
CallerName=test
CallerIDBlocked=False
OriginalCallingNumber=266155422
OriginalCallingOctet=0x0
OriginalCalledNumber=2915612767156
OriginalCalledOctet=0x0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=266155422
TranslatedCallingOctet=0x0
TranslatedCalledNumber=2915612767156
TranslatedCalledOctet=0x0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwReceivedCalledNumber=2915612767156
GwReceivedCalledOctet3=0x0
GwOutpulsedCalledNumber=15612767156
GwOutpulsedCalledOctet3=0x0
GwReceivedCallingNumber=266155422
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x80
GwOutpulsedCallingNumber=266155422
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x80
DSPIdentifier=1/3:0
Which is right but at the PABX I am not getting any digit.
Thanks again for your help.
140
