07-07-2003 04:52 AM - edited 03-13-2019 12:36 AM
I am trying to use a USB sound card for a fixed audio source. I can here the music locally from the sound card but can not get CCM to use it for music on hold, fixed audio source. I also see the USB Audio Device under device manager. Everything appears to be normal from a windows perspective. I have also stopped and started the Cisco IP Voice media Streaming Application. Has anyone made this work with a USB sound card before???
07-08-2003 09:06 AM
I am unsure if the usb sound card is supported. there is a link of supported sounds cards but I can not find it at the moment. One probelem that I has was getting them name in call manager to be correct. On the music on hold configuration page the fixed audio source device name has to be exactly as it appears in windows device manager.
hope this helps.
scott
07-08-2003 09:20 AM
Scott,
I have verified the name is exactly as it is in device manager. If you do run across the link of supported sound cards, please let me know.
Mark
07-09-2003 08:58 PM
Hi Mark,
There are definitely no supported sound cards for the DL320 platform, and there never have been. We hope to announce support for a USB-based sound device within the next few weeks, and that support will include the DL320G3 platform (a.k.a MCS-7825H-2266). I can already tell you that it will require a newer version of the win-OS-Upgrade that is currently available.
09-07-2003 07:48 PM
Dave,
Any new developments on sound card support for the DL320? I have a customer that is needing to implement MOH from a fixed device and found this thread. I thought I would ask since it has been a couple of months since your post.
Thanks!
Pat
