01-11-2009 10:08 PM - edited 03-13-2019 05:59 PM
In call Manager, I knew that FAC can can be applied for the route patterns.But pl clarify me whether, FAC can be configured for a particular user or Ip phone.
The version used is 6.0
Karthik
Solved! Go to Solution.
03-12-2009 12:06 PM
About Client Matter Codes:
I can do something like that: XXX[2-6]XXX
Something like a route pattern or a dial-peer configuration?
Thanks, Dante
03-12-2009 12:16 PM
no, only 0 thru 9 numeric values are accepted
java
if this helps, please rate
03-12-2009 12:17 PM
java
03-12-2009 12:33 PM
There are no way to do something like that?
Thanks, Dante
03-12-2009 04:39 PM
No, unless you rewrite the whole code for how CUCM works. only numeric values are accepted
java
03-16-2009 10:22 AM
And how many CMC Codes I can create in Callmanager 6.1?
03-16-2009 11:01 AM
Enter a unique code of no more than 16 digits that the user will enter when placing a call.
theoretically 9999999999999999
java
05-02-2009 02:57 AM
hi friend u can configure the FAC for a user(its not a correct and proper way)you can create different authorization code (ie. 123,124,125) by using same authorization level. and apply the authorization level in RP and give the different authorization code to users. as per the authorization code u can find out the CDR data.
Ramesh.k
