Forced Authorisation Codes - CCME
Does anyone know whether it is possible to configure Forced Authorisation Codes within CCME. I've had a bit of a look around and the only possible way i can see to do it is by using TCL scripts.
Am i over complicating things? Is there an easy way of doing this?
1 REPLY
Re: Forced Authorisation Codes - CCME
WIth CME 4.0 and with a not-officially supported TCL script, you can do FAC. Otherwise the only other way to do this is to use afterhour block pattern and then provide a pin number for people to login to make the call. This will not generate any CDR info like in the Callmanager world.
133
