Forward calls directly to voicemail
patrick.boyle
I have a receptionist at one of our customers that would like the ability to answer the phone, then forward a call directly to the destination's voicemail box. Seems simple enough, though I've never received this request before.
CUCM 6.1.2, Unity 4, Cisco 7970
Jaime Valencia
Transferring Calls Directly to Voice Mail with Cisco CallManager 3.2.2 spD
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800dea82.shtml
java
if this helps, please rate
java
Jaime Valencia
java
java
I have something very similiar in production on a CUCM 6.1.3 system. Although, rather than create a new VM Profile, I created a translation pattern that strips the * off and uses a "XferToVM" CSS which specifies a XferToVM partition that only contains the CTI RP of XXXX and is forwarded to VM. The example from that link is probably cleaner, but I hadn't read it before I setup my network.
Perfect. Thank you!
