Community Member
Forward-digits question with FXO ports and POTS dial-peer??
Please see the example below. My question is do I or do I not need to add
the forward-digits 7 to the following dial-peer?? The reason I ask is that on my 7940 phones sometimes a outbound call just hangs, no dialtone, no busy signal almost like my CME router doesn't know what to do with the dialed digits. Most times outbound calls are fine. I thought maybe NOT having the forward-digits command in the dial-peer might be causing the problem??
dial-peer voice 3 pots
description **Outbound line**
destination-pattern 9[2-9]......
port 0/1/0
Thanks in advance,
Tony
Hall of Fame Super Silver
Re: Forward-digits question with FXO ports and POTS dial-peer??
You do not need to add it as only the explicitly matched digits get dicarded on pots dial-peers, in your case the 9 and the 7 digits are send to PSTN. Your issue could be due to some overlapping dial-peers, make sure you have no overlapping ones.
HTH,
Chris
Community Member
Hi, thanks for responding. I have included my dial-peers for my configuration below. I do not see where they are overlapping. Could you take a quick look and give me a clue if I am missing something??
Thanks in advance,
dial-peer voice 100 pots
destination-pattern 51
port 0/0/3
dial-peer voice 1 pots
destination-pattern 9911
port 0/1/0
forward-digits 3
dial-peer voice 2 pots
destination-pattern 9T
port 0/1/0
port 0/1/0
dial-peer voice 4 pots
preference 1
port 0/2/0
forward-digits 3
dial-peer voice 5 pots
preference 1
port 0/2/0
dial-peer voice 6 pots
preference 1
port 0/2/0
dial-peer voice 7 pots
description **Outbound using Hunt3**
preference 2
clid network-number 8789953
port 0/1/3
forward-digits 3
dial-peer voice 8 pots
preference 2
port 0/1/3
dial-peer voice 9 pots
preference 2
port 0/1/3
dial-peer voice 10 pots
preference 3
clid network-number 7979999
port 0/0/2
forward-digits 3
dial-peer voice 11 pots
preference 3
port 0/0/2
dial-peer voice 12 pots
preference 3
port 0/0/2
dial-peer voice 13 pots
description **Outbound using Hunt2**
preference 4
clid network-number 8789999
port 0/1/2
forward-digits 3
dial-peer voice 14 pots
preference 4
port 0/1/2
dial-peer voice 15 pots
preference 4
port 0/1/2
dial-peer voice 16 pots
preference 5
clid network-number 7973803
port 0/0/1
forward-digits 3
dial-peer voice 17 pots
preference 5
port 0/0/1
dial-peer voice 18 pots
preference 5
port 0/0/1
dial-peer voice 99 pots
destination-pattern 2071
port 0/3/0
Dial-peer 5 with destination-pattern of 9T is your issue, what is the purpose of this one?
If you need a long distance and international dila-peers then create:
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
port 0/3/0
destination-pattern 9011T
prefix 011
port 0/3/0
Chris
309
