Forward Fax-Calls
dear all,
does anyone know, how can i forward all incoming calls for a pots-fax temporary to another external fax.
c3640#
voice-port 3/1/1
cptone DE
description FAX 2099
dial-peer voice 2099 pots
destination-pattern 2099
port 3/1/1
Re: Forward Fax-Calls
I am not sure exactly what you are trying to do. If you are wanting to forward all calls for 2099 to some where else then shutdown dial-peer voice 2099 and then create another dial-peer with a destiniation-pattern of 2099 and send the call where you want to.
Thank you,
-Mckee
The challenge is the location where the fax is, will closed but the extension 2099 is the known number for our customer and i want forward this fax for a while to another location of our copmany .
Thanks Mario
Then just make the changes while the office is closed. Then when the office reopens undo the change. Where is the new fax going to be? different city? state?
Thank you,
-Mckee
104
