Community Member
forwarded calls
CCM4.1(3), Unity4.0(1)
When calls to my IP Phone are forwarded to my cell number the Caller ID on my cell phone displays the incorrect calling number. For example:
UserA calls from 321-654-7890 to IP Phone 321-456-9870 (Phone has call forwarded to cell phone)
My cell phone caller ID displays incoming call from: 321-456-7890
Not sure if the CCM or dial-plans on the gateway are causing the prefix of the IP phone to be combined with the last 4-digits of the calling number.
Any one know how to fix this?
Thanks in advance.
1 REPLY
Blue
Re: forwarded calls
callingNumber Masks on lines, gateways and translationPatterns could be in play here. verify all callingNumber Masks are configured on the specific lines/gateways/Tpatterns that you would like.
you seem to have an '321456XXXX' callingNumber Mask set somewhere in your system.
check all gateways and translationPatterns first. it is a common practice to set the mask nearest the gateway used for the outbound call. (this of course could also be set on the line of the phone)
122
