01-11-2006 02:31 PM - edited 03-13-2019 11:48 AM
I have a user who floats around the campus filling in for people. She has a number of 1234 and has vmail setup on it when it's busy or N/A, what she needs to happen is when she's at another desk and forwards her phone to that desk and if she doesn't answer it at the other desk, she wants it ot go into her vmail, not the vmail of the desk that she is at temporarly. I'm not sure if this is possible.
Any input!
01-11-2006 02:43 PM
It should work as WAD, you need to check if you do not have configured a voice mail profile or something else that is avoiding that behavior.
01-11-2006 02:55 PM
I'm not what your saying here what's WAD? The 2 phones work as they should, so if I call users 1 and no one answers, it will go to her vm, if users 2 doesn't answer it will go to vm. But if user1 forwards her phone to users2 phone and user1 doesn't answer then phone at user2's desk, she wants it to go to her vmail not user2.
EM is not an option at this time, thanks anyway!
01-11-2006 03:05 PM
Yes, that's the way it should work, WAD (working as designed) it means that she should be able to hear her own voicemail not the one of the desk. That is why you need to check if you do not have some rule that is avoiding this behavior
01-11-2006 02:45 PM
I think the best option in this case would be extension mobility.
01-12-2006 06:16 AM
Hi Tony,
From what I know the Unity should work the way you want in regards to Forwarded calls.Check out this thread from the Unified Communications forum that address's this exact question.
What it indicates is that Unity will use the first redirecting number ie:the number of the user who floats from desk to desk and for any forwarded/ missed call it should revert to her mailbox.
Hope this helps!
Rob
