Forwarding to external numbers in SRST
In a small branch office the main number is forwarded (via CCM! Not directly on the router!) to the Call Center. In SRST (v3.3) mode I did not find any solution for this.
It would also be nice if the default-destination or forward noan / busy could be forwarded to an external number.
Does anybody have an idea? Is there any workaround for this?
thx in advance
Stephan
Re: Forwarding to external numbers in SRST
Stephan,
This should work. You will just need a dial peer that the destination number can match such as:
dial-peer voice 1 pots
destination-pattern 9T
port 0/1:23 (This will vary based on PSTN access)
call-manager-fallback
default-destination 95551111
call-forward busy 95552222
call-forward noan 95553333
Hope this helps. If so, please rate the post.
Brandon
Brandon,
For the busy / noan and default-destination it works fine. (i thougt i tested this before opening this discussion.)
I still have the problem, that the main number xxxxxxx777 should be forwarded to 9xxxxxxx888. This is normally done by the callmanager. We do not want to configure it directly on the router. The alias command cannot be forwarded to an external number. Any idea for this problem?
Stephan
287
