Frac PRI taking SLIP errors
rraver
I have a VWIC-1MFT T1 configured for a 12 channel frac PRI. The controller increases in Slip and Errored Secs when ever I put the
network-clock-participate wic 2
in the config. I have pasted the confing below:
clock timezone MST -7
clock summer-time MST recurring
ip cef
isdn switch-type primary-ni
voice-card 0
no local-bypass
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-12,24
interface Serial0/2/0:23
no ip address
encapsulation ppp
isdn incoming-voice voice
but I keep getting these errors.
rt-cl-ELIt1#show controllers t1 0/2/0
T1 0/2/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (375 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
151 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
151 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
2 Line Code Violations, 2 Path Code Violations
3 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 1 Degraded Mins
5 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 1 15 minute intervals):
2 Line Code Violations, 2 Path Code Violations,
3 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 1 Degraded Mins,
rt-cl-ELIt1#
Serial0/2/0:0 unassigned YES unset down down
Serial0/2/0:1 unassigned YES unset down down
Serial0/2/0:2 unassigned YES unset down down
Serial0/2/0:3 unassigned YES unset down down
Serial0/2/0:4 unassigned YES unset down down
Serial0/2/0:5 unassigned YES unset down down
Serial0/2/0:6 unassigned YES unset down down
Serial0/2/0:7 unassigned YES unset down down
Serial0/2/0:8 unassigned YES unset down down
Serial0/2/0:9 unassigned YES unset down down
Serial0/2/0:10 unassigned YES unset down down
Serial0/2/0:11 unassigned YES unset down down
Serial0/2/0:23 unassigned YES NVRAM up up
ANY IDEAS OR HELP ??
rraver
Whenver I call the line it says that there are no available lines, please call back later... Telco carrier says everything looks fine on there end.
for the slip issue, please configure:
network-clock-select T1 0/2/0 1
For the failed incoming calls, please take "debug isdn q931" with "term mon".
That has stopped the slip errors, what does that do? term mon hasn't helped me with the calls so I will have to do a console and see if it's dumping the debugs there. I do term mon first and then turn the debugs on and do term mon again just in case, but no luck still.
Thanks !
With ISR routers, you need use clock from a line for reference, and these commands let you do that.
If you don't see debu output, check "show logging". It's possible that someone has disable logging to terminal, in which case re-enable with "conf t" and "logging monitor". After that you should be able to see the debugs via telnet.
As a recognition to those providing answers, please rate posts using the scrollbox below!
