frame-relay cir statement
Just want to get confermation on my understanding. Based on the config below the maximum I can get out of this configuraiton (voice or data) when applied to an interface is 128K (even though the actual port speed is 256K).
map-class frame-relay map_class_frts128
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay mincir 128000
service-policy output policy_map_voice_remote
frame-relay fragment 160
Am I correct?
Re: frame-relay cir statement
you are correct..
must apply map-class to interface..
ketan
I've got a customer with a similar config and changed the cir and mincir to a little bit less than the actual cir as the values that IOS shapes to are approx. the value configured. Some documents on CCO say to use 95% of the CIR.
Silver
We often recommend this if the SP is very tight on the policing of the CIR - the traffic shaping engine is based on layer 3 traffic rates, so by dropping the cir etc values to 95% of the real CIR you allow the overhead the frame relay headers take up on the packet that the network switches.
111
