Frame relay QoS on separate voice and data PVCs
How does one configure VoIPoverFR QOS on a circuit with a separate voice and data PVC? I can't find any documents on that specifically. Everything I can find is geared toward a single PVC running both voice and data. I have a voice PVC 128k and a data PVC 128k. How do you make sure the voice packets go over the voice PVC and not the data PVC? I read one doc (on the CCO) that mentioned that they should be configured the same. Is that true if you want voice to go over one and data the other? Any help would be appreciated.
Blue
Re: Frame relay QoS on separate voice and data PVCs
The preferred method is to use route filters. Advertise only voice subnets over the voice link, and only advertise data subnets over the data link. This will be simpler if you have designed your network with easily summarized voice subnets. As an example, all your voice subnets might be covered by a 10.55.X.X range. You would then need 2 standard access lists, one that denies 10.55.0.0. 0.0.255.255 and permits any, and one that permits the 10.55 and denies any. You would then apply the access lists as distribution filters for your routing protocol on the subinterfaces outbound. This would be done on both routers.
Have Fun!
Dave
That sounds good. What about the map class statement for QoS? Does that get applied only to the voice PVC, or both PVCs as I had read? And what about the frame-relay traffic-shaping, applied to both interfaces? Below is the statement I'm using.
map-class frame-relay VoIP-128k
no frame-relay adaptive-shaping
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay mincir 128000
service-policy output QoS-128k
frame-relay fragment 160
access-list 100 permit ip any any precedence critical
access-list 101 permit ip any any precedence flash
Blue
You will need a map class for each PVC, but they will not be the same. The voice packets need to be priority queued.
Here is a very good document with examples that should get you going:
http://www.cisco.com/warp/customer/788/voice-qos/voip-ov-fr-qos.html
I understand the design issues you explained above. Maybe you can help with one more point. With separate voice and data PVC's, each running at 128K CIR, fragmentation must be enabled on both PVC's. However, I have had problems in the past with applications that turn on the "do not fragment" bit. Then if fragmentation is attempted, the applications have problems. How can this be addressed? Thanks.
Silver
There are some alternatives to using filtering of the routing updates.
Configure a loopback on both router, and use the h323-gateway voip bind srcaddr command to force the router to use the loopback address as the sourceof the VOIP signalling and RTP. Then use static routes to point to the remote loopback using the next hop IP address of the remote voice PVC. This way the voice traffic only travels via the voice PVC, and if the IP addresses of the loopbacks and voice PVC subinterfaces are kept out of the data subnets, the data traffic won't be routed via the voice PVC.
for example -
router 1
interface loopback 0
ip address 100.1.1.1 255.255.255.0
h323-gateway voip bind srcaddr 100.1.1.1
interface serial 0/0.1
ip address 100.1.10.1 255.255.255.0
frame-relay interface-dlci 16
class VOIP
ip route 100.1.2.0 255.255.255.0 100.1.10.2
router 2
ip address 100.1.2.1 255.255.255.0
h323-gateway voip bind srcaddr 100.1.2.1
ip address 100.1.10.2 255.255.255.0
class VOIP
ip route 100.1.1.0 255.255.255.0 100.1.10.1
Enabling FRF12 fragmentation is transparent to the upper layer protocols such as IP. the packet goes to the frame relay engine, is fragmented, has the headers wrapped around the fragment and then these fragments are queued. At the receiving side the fragments are received, glued back together to make the full packet and then sent to the destination interface. The FRF12 fragmentation should be of no conesequence to any applications that set the DF bitof the IP packet header.
as far as i understand you have 256Kb/s access rate (physical interface speed) and CIR=128Kb/s for data and CIR=128Kbit/s for voice. if so, then try this config:
interface Serial0/0
bandwidth 256
encapsulation frame-relay
frame-relay interface-queue priority
interface Serial0/0.1 point-to-point
description voice_pvc
bandwidth 128
ip address x.x.x.x
no cdp enable
frame-relay interface-dlci 100
class voice
frame-relay ip rtp header-compression
interface Serial0/0.2 point-to-point
description data_pvc
bandwidth 128
ip address x.x.x.x
frame-relay interface-dlci 200
class data
map-class frame-relay voice
no frame-relay adaptive-shaping becn
frame-relay bc 1280
frame-relay be 0
frame-relay interface-queue priority high
map-class frame-relay data
frame-relay bc 1280
frame-relay be 0
frame-relay interface-queue priority normal
frame-relay fragment 320
123
