07-16-2001 02:55 PM - edited 03-12-2019 11:58 AM
A question regarding FXO capabilities on the 2600 platform with CallManager. I have a branch office with 5 ip phones and two analog lines to the CO, 555-1212 and 555-2121. I want the ability to take and make calls via the FXO ports. I'm assuming I'll have a pots dial-peer for the inbound calls for 555-1212 and 555-2121. I'll take the inbound called-number (555-1212 or 555-2121), transform it to match the 4-digit extension for the attendant, and VOIP dial-peer this towards the CM. For outbound calls, I'll route back to the FXO ports appropriately. Any problems with doing things this way or will I need the VIC-2DID? Thanks.
07-17-2001 11:57 AM
Sounds good to me.
08-02-2001 10:11 AM
When you say transform it to match the 4-digit extenstion, are you using 'connection plar xxx' (w/ xxx being the extension of the auto attendant)?
08-02-2001 12:45 PM
Connection plar would work. What I was wanting to do is to construct a translation pattern that matches DTMF digit strings and changes the dialed-digits before sending to the CallManager. I've made this work on ISDN PRI but didn't know if it was able to be done using analog FXO.
