FXO and Rauland system integration
douglas.wolf
I am trying to integrate an FXO card on a 1750 router to go into a Rauland Telecenter 21 master port for paging control.
I have a route pattern configuration of 3054 (the extension I want to dial to reach the Rauland), set to my restricted partition, set to route the pattern, and set to the appropriate gateway that the FXO card is installed in. Am I doing something wrong? what should my config look like on the 1750?
jkoniecki
Douglas,
Can you post your show version and show run ?
Have you ever made any calls out of this 175X router ?
Jk
The 1750 used to have an fxs in it, worked fine. Replaced with FXO, but I'm not convinced that there isn't something else I'm supposed to configure.
Thanks for the help --
Here's the show run:
User Access Verification
Password:
MS-Gateway_251>en
Password:
MS-Gateway_251#show run
Building configuration...
Current configuration : 1155 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname MS-Gateway_251
logging rate-limit console 10 except errors
enable password
memory-size iomem 25
ip subnet-zero
no ip finger
no ip dhcp-client network-discovery
call rsvp-sync
interface FastEthernet0
ip address 10.1.0.251 255.255.0.0
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.0.1
no ip http server
voice-port 0/0
voice-port 0/1
voice-port 2/0
timeouts interdigit 5
description FXO
station-id name 3054
station-id number 3054
voice-port 2/1
description FXO
station-id name 3055
station-id number 3055
dial-peer voice 10 voip
incoming called-number .
destination-pattern .T
session target ipv4:10.1.4.1
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
ip precedence 5
no vad
dial-peer voice 22 pots
destination-pattern 3054
port 2/0
dial-peer voice 23 pots
destination-pattern 3055
port 2/1
line con 0
transport input none
line aux 0
line vty 0 4
password thinmint
login
end
MS-Gateway_251#
HERE's the show ver:
MS-Gateway_251#show ver
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(1), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 27-Apr-01 08:47 by cmong
Image text-base: 0x800080E0, data-base: 0x80A59274
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
MS-Gateway_251 uptime is 2 days, 6 hours, 13 minutes
System image file is "flash:c1700-sv3y-mz.122-1.bin"
cisco 1750 (MPC860) processor (revision 0x601) with 24576K/8192K bytes of memory
Processor board ID JAD05030ME4 (2974950972), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
4 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
MS-Gateway_251#
baysjohn
Where's the FXS device that you will be using to dial? FXO is the Office side, so an Office to Office link can be set, but there needs to be a FXS (handset) somewhere to activate the FXO trunk. If you're plugging a regular phone into the FXO port, this wont work, you need an FXS port on your 1750.
The rauland side willa ct as the FXS and provide battery and dial tone.
