FXO Caller Id display intermittent
I have a problem with one of my fxo ports sometimes it won't display the caller-id of a call. I tried to connect a caller-id device (telco owned) between the telco line and the fxo port to check if the caller-id device won't also display the caller-id. I found out that the telco caller-id device is consistent in displaying the caller-id. So i concluded that it is on the router side that is causing the problem. I have already swapped fxo cards but still i continue to encounter the problem.
Could the problem be on the IOS? If somebody knows the solution kindly help.
Thank you very much.....Arvin.
Silver
Re: FXO Caller Id display intermittent
Try using the command "station number xxxxxxxxx" under the voice port .
Thanks for your reply.
I've tried the command "station number xxxxxxxxx" but the router won't accept it.
What do you mean by the command?
Arvin
122
