FXO connection using H323 cannot make call at the same time
I have a router 2620 with 2 port FXO module connect to PSTN and LAN with CCM (3.08). After complete the configuration. The router work with port by port.
It cannot make call at the same time.
What kind of information need to confirm in the config.
Matthew
Re: FXO connection using H323 cannot make call at the same time
How about pasting the config into the forum post so we can look at it?
Here is the config for the gateway.
When a call is using the voice port 1/0/0.
(voice call in & out through 1/0/0 is work)
We cannot make another call through port 1/0/1.
hostname Call_Gateway
ip subnet-zero
no ip source-route
no ip finger
no ip domain-lookup
call rsvp-sync
voice class dualtone 70
freq-max-power 6
freq-min-power 25
freq-power-twist 15
freq-max-delay 16
freq-pair 1 480 620
cadence-min-on-time 50
cadence-max-off-time 200
cadence-variation 8
interface FastEthernet0/0
description LAN Connection
ip address 10.1.2.175 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.2.254
ip route 0.0.0.0 0.0.0.0 Null0 255
no ip http server
no logging trap
access-list 51 deny any
voice-port 1/0/0
cptone HK
timing percentbreak 60
connection plar 1256
supervisory disconnect dualtone pre-connect voice-class 70
voice-port 1/0/1
cptone HK
connection plar 1250
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern .T
port 1/0/1
dial-peer voice 2 voip
destination-pattern 1256
session target ipv4:10.1.2.154
codec g711ulaw
dial-peer voice 3 voip
destination-pattern 1250
session target ipv4:10.1.2.151
codec g711ulaw
dial-peer voice 4 pots
port 1/0/0
line con 0
transport input none
line aux 0
access-class 51 in
line vty 0 4
password powerline
login
ntp server 10.1.2.200
end
There are a few things you can try to find out what is going on.
1) Unplug the line from port 1/0/1 and plug a regular telephone into it, make sure you get dialtone and can make and receive calls.
2) Unplug the line from port 1/0/0 and leave 1/0/1 plugged in. Try to make an outbound call from an IP phone. Does it work?
3) Make sure that the RJ-11 wires you are using between the FXO VIC and the jack are only 2-wire, not 4-wire. If you use 4-wire cabling, the VIC could be dedicating both DSPs to port 1/0/0 since we support 2-line capability on both the FXO and FXS VIC card.
237
