Community Member
FXO dial-out problem on new MC3810 setup
Good evening,
I am in the process of building a CallManager 3.2 and Cisco MC3810 lab in my home office to study with and I'm having problems getting off the ground. I'm running IOS 12.2(7).
I am using a single FXO port for incoming and outgoing calls. Using plar on the FXO, I am able to ring incoming to my phone via CallManager, or plar via a local FXS port.
However, I cannot dial out, at all, either from a local FXS port or via CallManager using the stock 9.@ rule using any phones. CallManager can call my FXS ports fine, so I know the codec and everything else is working on CallManager.
When I try and dial 9 and my cell number, the dialtone disappears after 9 and my number, pauses for about 9-10 seconds and then gives me a high-pitched beep repeatedly.
Here is my truncated voice configuration:
voice-port 1/1
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/6
connection plar 4640
description FXO to PacBell PSTN
codec g711alaw
dial-peer cor custom
dial-peer voice 20 voip
destination-pattern 80..
session target ipv4:192.168.0.75
codec g711alaw
dial-peer voice 21 voip
destination-pattern 4640
codec g711alaw
dial-peer voice 10 pots
destination-pattern 9T
port 1/6
Thanks for any help you can give me!
-Pat
1 REPLY
Re: FXO dial-out problem on new MC3810 setup
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
112
