FXO disconnection problem with SIEMENS HIPATH 3550
Dear Sir,
I've connected 4 x FXO ports on the Hipath 3550 and I'am experiencing the well known FXO supervision problem. When a call is placed from the PBX side it is properly routed and establised but when the user hungs-up the phone  the call remains up on all relevant involved call legs.
I have tried all possible configurations on the Voice GW that is recommended by CISCO with no luck.
Could you please advice?
Hardware Configuration:
Cisco Voice GW:
Cisco 2821 - IOS 12.4(22) YB4
FXO Card: VIC2-4FXO (installed on NM-HD-1V Voice Network Module}
PBX
Siemens HiPath 3550
Country
Greece
BR/Dionisis
We are having a similar issue, did you get around to finding a fix.
Any solution exist for this
Any solution exist for this problem ?
Yes, hookup a sound recorder
Yes, hookup a sound recorder to the system, playback the tone and graph it out to work out the Cadence settings, we had to do this a few years ago and it worked. Something similar to this article: https://supportforums.cisco.com/discussion/12211351/cme-fxo-usual-tone-disconnect
Did the same work for siemens
Did the same work for siemens hi path or any other vendor ? I talked to the vendor two days ago and he told me that, hi path pbx does not send any disconnect tone (so i cannot deduce the frequency and cadence values) however only a message with "Disconnect" is sent.
try on voice port cptone germany or greece or another
769
