Community Member
FXO-FXO Connectivity Issues
Is it feasible to use fxo ports in both routers to connect the PBX?
1 REPLY
Anonymous
N/A
Re: FXO-FXO Connectivity Issues
The reason is FXO to FXO connections are not supported
The only supported combinations are
1.E&M -to- E&M
2.FXO to FXS
3.FXS to FXS
So alternatively need to get E&M cards for bi-directional cummunication. If you have FXS interface the call will work in one direction only.In fxo-to-fxs dial-tone will be provided via the PBX with the fXo connection and the pbx with thefxpo would be able to pulse out digit to intitiate a call setup.
Best bet is to use E&M or T1/E1 cards on the PBX.
146
