FXO --> PSTN configuration problems
Okay, I have a CCM 3.2 box running mgcp to a 2600 with a FXO card in it. I can pickup the voip phone, dial 9 and dialout through the FXO with no problem.
My problem is the otherway around. The Directory number of the voip phone is 6025551212 (real # ommitted) and on the 2600 I have a connection plar 6025551212 but when the I do a test call into that number, normal phones hanging off that same POTS line ring, but the voip phone never rings on that directory number.
I can see the "sho voice call sum" status change to Ringing though. What configuration am I missing here?
I've tried a couple different things. Alot the configs I've tried, I'll get a secondary dialtone when I call into the number on the FXO and a couple seconds later a fast busy.
Please advise
Thanks in Advance!
-jjf-
1 REPLY
Re: FXO --> PSTN configuration problems
Turn on debug voip ccapi inout at a time when this will be the only call on the gateway. search the text for called= XXXXXX , this is the called number sent to call manager. make sure it matches how you will route the calll in CM.
Make sure to enter 'un all' when done
98
