FXO not Accepting digits
Dear all
THis is an extremly urgent issue and need to be resolved asap.
I have a IPT network with CCM 4.2,Cisco Unity Connection 1.2,Voice Gateway 2821 with FXO ports.
here is the call flow,
The user calls from outside is directed to CCM route point 9001 which directs the call to unity call handler
acting as IVR .
Now the problem i am having is that if somebody calls from outside and the IVR is played asking the
user to input the digits ,if the user presses an extension the IVR continues to play and the digits are not accepted.
Now why are the digits not accepted ??? and if continue to press numbers some of the time the IVR says u have
dialed incorrect extension.But basically it is not accepting digits.
VERY IMP Thing: This is only happening when i am calling from a land line
if i call from any mobile network to IPT network ,it never happens and everything works perfect.IVR is ok and extension dialing
is ok.
I am attaching the config of my gateway .Please have a look .May be i am missing some commands.
regards
Nouman Khan
Re: FXO not Accepting digits
Nouman,
I don't see your configuration attached. Are you using MGCP or H.323 on the gateway. One thing to check is dtmf relay. If you're using H.323, you should have "dtmf-relay h245-alphanumeric" in dial peer configuration for the dial peer pointing to Unity. If you're using MGCP, you should have the command "mgcp dtmf-relay voip codec all mode out-of-band" in global config.
Hope this helps. If so, please rate the post.
Brandon
Here is the config ,
sh run
Building configuration...
Current configuration : 5859 bytes
version 12.4
no service timestamps debug uptime
no service timestamps log uptime
hostname Gateway1
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.124-3f.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
no logging buffered
no aaa new-model
resource policy
ip subnet-zero
--More-- !
ip cef
ip domain name yourdomain.com
voice-card 0
no dspfarm
voice service voip
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
--More-- h225 timeout setup 3
voice class custom-cptone 1
dualtone busy
dualtone ringback
dualtone reorder
dualtone out-of-service
dualtone number-unobtainable
dualtone disconnect
frequency 425 425
cadence 200 200 200 200
voice translation-rule 1
rule 1 reject //
voice translation-profile block
--More-- translate called 1
interface GigabitEthernet0/0
description ****** Connection to Cisco-3560*******
ip address 10.10.11.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
voice-port 0/2/3
translation-profile incoming TransIVR
voice-port 0/3/0
supervisory disconnect anytone
supervisory custom-cptone 1
--More-- input gain -6
output attenuation 6
echo-cancel coverage 24
cptone BR
connection plar opx 4444
caller-id alerting dsp-pre-allocate
voice-port 0/3/1
input gain -6
cptone BR
voice-port 0/3/2
input gain -6
--More-- cptone BR
voice-port 0/3/3
input gain -6
cptone BR
dial-peer voice 1 voip
description Connection to CCM
destination-pattern 1...
voice-class codec 1
voice-class h323 1
--More-- session target ipv4:10.10.3.10
no vad
dial-peer voice 2 pots
destination-pattern 9T
port 0/3/0
dial-peer voice 3 pots
preference 1
port 0/3/1
dial-peer voice 4 pots
preference 2
port 0/3/2
dial-peer voice 6 voip
destination-pattern 0
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 8 voip
description Connection to Unity
destination-pattern 9001
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 9 voip
destination-pattern 4444
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 5 pots
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.10.11.2 port 2000
max-ephones 52
max-dn 52
Try this on your voip dial peer
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
I'm facing the same problem, if you solve this issue could u post it.
yes we did resolve the problem.
Actually we set the input gain and output attanuation to a different value .We changed it to default and the problem was resolved.
do u have TAC access?
try to see this case 605228183
regards
Nouman Khan
260
