FXO paging issue
I am trying to use a fxo port to intergrate to a Bogen amp. I have done this before with no issue but it may have been a different model. When I hook to the amp and call the number I have steered to the fxo. It immediatly disconnects. Its like it wants to see battery. I hooked it to a loop start line to test and whin I dial the number I get dialtone and it stays connected. So I think the port works but wants to see battery. Is there a way to program the port to just keep the connection up no matter what or am I missing something else here?
Re: FXO paging issue
Are you sure you should be using a FXO port? I would have thought an FXS would have been more appropriate.
I did something similar with an RT system and set it as ground-loop so that it would disconnect properly and it works fine.
Most paging systems are configured to work with a FXO port and require an additional adapter for an FXS. I have intergrated many different phone systems to paging using FXO but it seems that Cisco does not give you a plain old dumb FXO port. It wants to see talk battery to maintain the connection. I am hoping there is some command to disable the sensing of battery and just patch the audio through.
Bronze
voice-port x/x/x
no battery-reversal
shane.orr -- I knew somebody with that same name. Where did you go to high school? email me if you remember ogarza@presidio.com
209
