FXO, PBX or where is the solution?
We have ATA186 --------------1751V with FXO
PBX Meridian---------PBX Panaconic
We have a phone number for connecting to the FXO. Codec is everywhere G.723, we configured ATA186,
On 1751V configured gateway H323 on Ethernet interface and configured FXO.
The problem is next:
In the period of ringing with dialing from analog phone to ATA though our network, we hear or long beep of some other tone, add number of ATA and the connections begin OR we hear beep of phone-in, so FXO cant take a signal from PBX.
The puzzle is that with the same configuration of Cisco we have or first normal situation (for example20 times) or second.
Here is debug(with second situation):
21:03:41: [2/0] rcv from dsp sig DCBA state 0x0
21:03:41: htsp_process_event: [2/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
21:03:41: htsp_process_event: [2/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
21:03:42: [2/0] rcv from dsp sig DCBA state 0x0
21:03:42: htsp_process_event: [2/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
It will continue to infinity.
Don’t know where is the problem? May be with PBX?
Cisco configuration:
no logging buffered
memory-size iomem 15
ip subnet-zero
no ip domain-lookup
no cdp enable
ip classless
voice class codec 4
codec preference 1 g723r53
codec preference 2 g723r63
fax interface-type fax-mail
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address ***
speed auto
no cdp enable
h323-gateway voip interface
h323-gateway voip h323-id CIS_Centr
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.780 point-to-point
ip address ***
no cdp enable
frame-relay interface-dlci 780
ip route 0.0.0.0 0.0.0.0 ***
no ip http server
no ip pim bidir-enable
no cdp run
snmp-server community public RO
call rsvp-sync
gateway
voice-port 2/0
timeouts initial 0
timeouts call-disconnect 1
timeouts ringing infinity
timeouts wait-release infinity
no battery-reversal
voice-port 2/1
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern ...
no digit-strip
port 2/0
forward-digits all
dial-peer voice 2 voip
description to us to ATA186
destination-pattern 001
voice-class codec 4
session target ipv4:***
dial-peer voice 3 pots
destination-pattern 2...
no digit-strip
port 2/0
forward-digits all
1 REPLY
Bronze
Re: FXO, PBX or where is the solution?
As per my knowledge, the issue might be with the PBX. Make sure that the PBX conncetions and configurations are correct.
106
