FXO port config for an H323 gateway using CCM 4.2
I'm configuring a 2811 gateway using H323 that has 4 x PSTN lines which carries the same DDI number. This will then use call manager to distribute the call to an end user phone.
Firstly - do I need to configure the FXO ports as a plar connection with the DDI number?
Secondly - for an outbound dial peer, will I have to give all of my destination patterns 4 preferences as to which voice-port to use??
Dave
Green
Re: FXO port config for an H323 gateway using CCM 4.2
1.Correct, configure the plar under voice-port then your VOIP dial-peers.
2. You can do it and I would say it is a best practice.
Thanks for the response. Do I need to configure it as connection plar or connection plar opx??
Cheers
Dave
277
