FXO Port QOS Volume Issues
I currently have a customer who is running FXO ports to connect to the PSTN. They a are having problems with the Volume on the calls. Inbound or outbound whenvere we reciev from the PSTN or call to the PSTN the phones have to be on 100% volume to even hear the person and that makes a problem with echop on the phone when it is turned up over 75%. I have messed around with the Input gain and output attenuation but nothing helped. I am running MGCP, CCM 3.1.2(C) with IOS 12.1.5XM4.
What should i do?
Re: FXO Port QOS Volume Issues
Try kicking up the input gain on the FXO ports. See
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_access/vg_200/vg200xm1.htm#xtocid2301611
Call me after you do this. SG.
I forgot to mention, set the output attenuation back to default and then I think you have to shut/no shut the port for it to take effect.
322
