Community Member
FXO problem
Situation :-
we are facing a problem with FXO ports,We are using vic2-4FX0 with 2801 router (CCME).When we execute cisco IVR script (its-CISCO.2.0.1.0.tcl) for incoming call legs (for my company PSTN number) , its work fine. but when external user from PSTN disconnect its phone my internal phones or operator phone continuously rings. there is no automatic disconnection possible. only one way operator can disconnect his phone or stop ringing by manually pressing button on his phone set. Without execution of IVR script all things work fine no disconnection problem occur .
We have checked with both versions
i) Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ii) (C2801-IPVOICE-M), Version 12.3(14)T7
Hall of Fame Super Gold
Re: FXO problem
you are experiencing the classic supervision disconnect problem. After the caller hang-up, the system has no way to know that he/she has abandoned the call. Please see:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Note, unless you are in north america, ground-start signaling is not available.
Battery reversal and power denial may or may be not available depedning on your location.
Most likely you will need to configure disconnect supervision based on tones. This can be a little difficult, but is explained in the document above.
Community Member
Re: FXO problem
Dear Sir i have checked all the commands which are mentioned in the cisco document (
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml )
But still i cannt resolve this problem. I dont know what i am doing wrong .
These are my debugs which i found .
This is the debug when External PSTN user has disconnect its phone . but operator status is still off-hook.
debug vpm port 0/0/0
debug vpm signal
duplex auto
speed auto
May 26 04:45:41.475: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100].110 255.255.255.0
duplex auto
ling time=05/26 04:45 orig called=
May 26 04:45:41.479: htsp_process_event: [0/0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SE
TUP_ACK]
May 26 04:45:41.479: fxols_wait_setup_ack:
May 26 04:45:41.479: [0/0/0] set signal state = 0xC timestamp = 0fxols_check_aut
o_call
May 26 04:45:41.487: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_SETUP_
ACK]
May 26 04:45:41.487: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_PROCEE
DING]fxols_offhook_proc
May 26 04:45:41.487: htsp_timer - 120000 msec
May 26 04:45:41.487: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_CONNEC
T]fxols_offhook_connect
May 26 04:45:41.487: htsp_timer_stop
May 26 04:45:41.491: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT
_THROUGH]fxols_connect_proc_voice
May 26 04:45:41.751: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0110]f
xols_rvs_battery
May 26 04:46:01.483: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT
May 26 04:46:22.035: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT
May 26 04:46:42.587: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT
show voice trace 0/0/0
Router#sh voice trace 0/0/0
0/0/0 State Transitions: timestamp (state, event) -> (state, event) ...
13006.688 (S_SETUP_IND_PEND, E_VTSP_DSM_OPEN_SUCCESS) ->
13006.696 (S_SETUP_INDICATED, E_CC_SETUP_ACK) ->
13006.696 (S_DIGIT_COLLECT, E_CC_PROCEEDING) ->
13006.696 (S_PROCEEDING, E_CC_CONNECT) ->
13006.684 (FXOLS_RINGING, E_DSP_SIG_0100) ->
13006.688 (FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK) ->
13006.696 (FXOLS_PROCEEDING, E_HTSP_SETUP_ACK) ->
13006.696 (FXOLS_PROCEEDING, E_HTSP_PROCEEDING) ->
13006.696 (FXOLS_PROCEEDING, E_HTSP_CONNECT) ->
13006.700 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
13006.960 (FXOLS_CONNECT, E_DSP_SIG_0110) ->
13026.692 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
13047.244 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
13067.796 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
13088.348 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
13108.900 (FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH) ->
This is the Result when operator manually disconnect its ip phone.
May 26 04:47:58.563: htsp_call_bridged invoked
May 26 04:47:58.575: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT
May 26 04:47:59.979: htsp_timer_stop3
May 26 04:47:59.987: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_RELEASE_R
EQ]fxols_offhook_release
May 26 04:47:59.987: htsp_timer_stop
May 26 04:47:59.987: htsp_timer_stop2
May 26 04:47:59.987: htsp_timer_stop3
May 26 04:47:59.987: [0/0/0] set signal state = 0x4 timestamp = 0
May 26 04:47:59.987: htsp_timer - 2000 msec
May 26 04:48:00.259: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110
May 26 04:48:01.987: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_T
IMER]fxols_guard_out_timeout
May 26 04:48:01.987: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Can you please define the exect commands ?
I will be looking for your kind reponse.
Re: FXO problem
you need to configure supervisory disconnect based on tones. I cannot help you with exact commands, I would need to know where are you located and the tones that the CO switch sends when the caller disconnects.
Start with the examples, try to figure out the disconnect tone, and if problems post your config here.
This is the only solution with FXO ports. Else, you would need to use ISDN BRI, on which the problem never happens.
Thanks for the nice rating and good luck!
435
