Community Member
FXO PSTN Gateway
Hi Guys,
I will appreciate your input on this problem. I have setup a FXO port as a gateway to the PSTN network for a lab IPT POD. Outbound calls work just as expected but inbound just doesn't work at all.
Rings are heard at the calling end but not called, but after 3rings the calling end goes dead whiles a check on the gateway still indicates an off hook.
It's a BT (British Telecom) analog line by the way.
Any ideas? Port configs below.
ccie-R1#sh voice port 1/0/0
Foreign Exchange Office 1/0/0 Slot is 1, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Playout-delay Mode is set to default
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for GB
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 5
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Re: FXO PSTN Gateway
Common Problem....
For example, if you have extension 4444 that you want all your incoming calls to goto you need to do something on the router.
Go into configure mode and into the voice-port interface that your incomming calls are coming into. ie: Voice-port 1/0/0
Add this line:
connection plar 4444
Ctrl-Z and write the config. Try dialing into the voiceport now and extension 4444 should ring on your voip phone. In my systems of FXO dialin, I take the extension specified in connection plar xxxx and point it to a basic IVR 100% of the time that lets you move the incoming caller about the system.
Hope that helps!
Community Member
Cheers!! PLAR works fine and this question is juet food for thought.
I trust translation rules can fix this problem too. I not sure if CLI / callerid comes though on the line but my intention will be somthing like this ....
translation-rule 1
Rule 1 ^. 01908601000
On the voice port.
What are your thoughts?
Community Member
Could you show the config, especially the dial-peers?
181
