06-28-2002 02:29 PM - edited 03-12-2019 07:32 PM
I am stuck with the following scenario:
PBX ---FXO ---A:1750 --PPP-- B:1750 --FXO --PBX
Whenever site A dials B (or vice versa) the call is not disconnected even if B answers and hangs up.
I tried in vain all the solutions form Cisco concerning this matter (ground start signaling – Power denial – Supervisory disconnect – Battery reversal) and unfortunately I cannot use any E&M or FXS ports.
May a have the basic configuration of this FXO/FXO scenario (to make sure that I don’t have any configuration errors) and a possible way to resolve the disconnect problem?
thanks
06-28-2002 02:29 PM
Refer to the following document:
http://www.cisco.com/warp/public/788/signalling/fxo_disconnect.html
Make sure you implement them correctly, i.e. to use groud
start signalling, you need to have this type of signalling configured on
both sides and also need to connect a jumper on the fxo card itself.
07-01-2002 06:36 AM
