Community Member
FXS Call disconnect Isuue
I have got two fax connected to the FXS port on 2811 router. The router is configured as MGCP gateway.
We have noticed that the fxs ports shows us connected even the call is disconnected from the other end. We have to reset the ports 3-4 time ina days to keep it working..
After reboot the things work fine..
Any help will be appreciated.
TIA
Silver
Re: FXS Call disconnect Isuue
try this link for troubleshooting the voice issue
http://www.cisco.com/warp/public/788/AVVID/fix_1way_voice.html
Community Member
Hello Tia,
This problem might be due to the IOS version
can you check your IOS version and check the cisco bug tool.
Omar
189
